Author Topic: Trouble finding Misty Moorings Ops  (Read 3230 times)
Dragnhorn
« on: July 22, 2013, 12:52:13 AM »
Misty Moorings Ops (Updated) - By Doug Linn
Rob Abernathy
aka Dragnhorn
PC specs:
Re: Trouble finding Misty Moorings Ops
« Reply #1 on: July 22, 2013, 01:59:45 AM »
Isn't it on the "Scenery" page under "M"?  I just went there to check, and it shows up for me.  ;D
Dragnhorn
« Reply #2 on: July 22, 2013, 10:57:35 AM »
Found it.  Thanks.  It was a long day!
Rob Abernathy
aka Dragnhorn
PC specs:
« Reply #3 on: July 22, 2013, 02:57:10 PM »
There is a small problem with the update because the original file was named RTMM Oil Rig_Ops and the update is named RTMM MM_Ops.  Could result in duplicate .bgl's unless old file is deleted from FSX Scenery Library.
Of course I could be wrong and had changed the original name myself (brain fart #1 for today) but need to check it out in case I'm right.
« Last Edit: July 22, 2013, 02:59:32 PM by spud »
Dragnhorn
« Reply #4 on: July 22, 2013, 05:21:04 PM »
I better go check that myself Spud.  I saw I already had MM Ops so I left it alone.  Back to downloading and checking!
Rob Abernathy
aka Dragnhorn
PC specs:
« Reply #5 on: July 22, 2013, 08:11:49 PM »
Rob,
I may be all wrong because ICRS (I can't remember s**t) and I also rename all my files by appending a MM on the front so they can be all grouped together alphabetically when I use explorer to manipulate my files.  OK I'm anal but then I have an excuse (age).
« Reply #6 on: July 28, 2013, 03:54:41 PM »
I usually try to keep the name the same, for 2 reasons, one for just what you are talking about, but a second reason is for "speed" when I'm updating. When I make the name the same, I go to FSX, copy the folder there (which was the old name), then go into the server file and delete the one there and paste the one I copied. Doing this, I don't have to re-do the HTML changing link names.  It also keeps folks from having duplicates.
For the folks not using DX10, no reason to download the DX10 ready one ... they will only see a different picnic table or cabin. For the DX10 people they WILL SEE a picnic table or cabin! :-)
