OK, here's some easy fixes for some problems encountered. Sometimes the problems are very obvious, including "ditches" around a runway, or a canyon beside it ... even a wall of dirt. Below are two before and after shots for PAKT and PAED. What Traffic_360 has done is increase the parking area (and this is a good thing most of the time). But where we have placed some things at airports, there could be a problem. All you have to do is go to FSX/Just Flight/Traffic 360/Airport Facilities/Scenery and search for the ICAO code. When you find it, rename the ".bgl" to ".off" and you will have the original airport configuration. This does not "knock out" the traffic added by Traffic_360 ... it is still there, just not using the new parking areas they have designed. (Interesting PAJN was not affected).
As we "play" with this program, we will keep you posted. So far, other than these small things, there seems to be good traffic, including GA at our focus airports.
PS to Jeff ... regarding the ORBX NA GA program ... I just found this in the Scenery/World/Scenery
Traffic_FTX NA GA Traffic_Full Call Signs.bgl.OFF
Looks like Traffic_360 might have turned it off, I sure didn't.
