Author Topic: Some SAK time  (Read 1292870 times)
Some SAK time
« on: March 28, 2013, 12:47:18 AM »
Here's some pictures I took on my trip from Hoonah to Skagway.  ;)   The landings are at Sisters Island, Haines, and then Skagway.  I thought that the light brown and gray paths and associated buildings at Skagway looked funny.  I had to make sure they are FTX objects.  They aren't!!  ???
I've switched to a link to photobucket for the slideshow.  Hopefully this will reduce my bandwidth.  ;)
https://photobucket.com/u/jeff3163/a/681c1b26-25da-4020-b702-6bf559a304a9
« Last Edit: August 25, 2023, 05:38:28 PM by jeff3163 »
Re: Some SAK time
« Reply #1 on: March 28, 2013, 01:23:50 AM »
Great Shots, Jeff!!! :)
Just Fly
Re: Some SAK time
« Reply #2 on: March 28, 2013, 05:14:05 AM »
Hey Jeff!
There must be some compatibility issues at your end. Those grey and brown lines don't look ORBX style at all! Here is how Skagway should look like, according to Iain Emms's screenshots posted over ORBX Preview forum:
For some reason, Haines looks odd too on your end...
That being said, those are great screens for sure!
Cheers,
Just Fly
« Last Edit: March 28, 2013, 05:16:17 AM by Just Fly »
Regards,
Just Fly
FSX Acceleration | Windows 7 (x64) SP1 | Intel i7 920 @ 2.66 GHz | HIS Radeon HD 6570 1GB | 6GB RAM | HP 1825 18'' @ 1280x1024
Re: Some SAK time
« Reply #3 on: March 28, 2013, 10:07:19 AM »
Jeff,
I watched your slide show, pretty neat.  Nice screen shots but I notice a problem at Skagway from the overhead screen shots.  I know this because I found it in my installation as well and I'll tell you how to correct it.
At Skagway those light brown "streets/taxiways" are not supposed to be there.  It is caused by a spurious .BGL file I found in my 'Master Scenery Library'  I believe you have that file as well.  If you will look in the scenery sub-folder of the library for a file named:
 a_b_PAGY_ADE_FSX.BGL
just disable it by adding .OFF to the file name and Skagway will improve quite a bit.
Matter of fact there should be several files in the same area of the sub-folder that start with a_b_(XXXX).......,
these are ADE files but I do not know where they came from.  Most have MCW in the file name those are usually the initials of the person who made them.  Notice that the PAGY name has FSX instead.  All of these ADE files are for airports in Alaska and most of them are outside the SAK area but I disabled all of them with the .OFF extension and visited each one to make sure the airport was still working with them disabled.
I'll load up the sim later and post a screen shot of PAGY with the file turned off to show the difference.
For now trust me and find the files and disable them.
Re: Some SAK time
« Reply #4 on: March 28, 2013, 10:39:10 AM »
Hopefully the screenshot will show in this post.  I have not been to Photobucket site for a long time and it has all changed and I'm not sure how to work it any more so here goes! .........
http://i70.photobucket.com/albums/i97/spud004/RTMM%20Scenery%20order/GCS_0085_zps5c4d1195.jpg
Well, not what I wanted but clicking the link should get you the shot of how PAGY should look.
(Don't know which link to pick to show the photo in a forum post.)
« Last Edit: March 28, 2013, 10:41:17 AM by spud »
Re: Some SAK time
« Reply #5 on: March 28, 2013, 07:55:49 PM »
Here is your pic, Spud -   ;)
Skagway with "a_b_..." files disabled:
Thanks Just Fly and Spud, for the help with my PAGY problem.  I knew there would be a solution when I got home from work.  I have already disabled a few of the UTX bgl's that are hanging out in my Scenery/world/scenery folder.  (even after I had UTX disabled already)  I will go hunt down the file you told me about now, and then I can continue my flight up the railroad tracks.   8)  ;D  8)
Edit- Ok, I've turned off all the "a_b..." files.  Now I'm heading for Skagway to check it out.  Thanks again, Spud.  8)
« Last Edit: March 28, 2013, 09:10:18 PM by jeff3163 »
Re: Some SAK time
« Reply #6 on: March 28, 2013, 08:57:32 PM »
I am at Skagway.  It looks good.  It is almost 6pm here, so it's dusk in FSX land.  I've got runway lights. :)
(Edit:  All Photos now displayed in slideshow link at top of thread.)
« Last Edit: April 22, 2020, 10:39:52 AM by jeff3163 »
Re: Some SAK time
« Reply #7 on: March 29, 2013, 02:01:10 AM »
Hi guys
I thinks that it's come .... at the instal  Scenery
When you instal a Region ORBX  before , unswitch FTX central  and lets on "" FSX default  ""
if you instal an airport to a region switch FTX  on this region that work fine
I look directly on Skagway  my instalation  and looks great  whithout tweaking BGL . off
this my screen
Near the PLACE SPUD SCREEN
With DX10 SHADER S.J.PARSON  General10 V3.2.2
Neptune
« Last Edit: March 29, 2013, 02:23:39 AM by NeptuneP2V7 »
Re: Some SAK time
« Reply #8 on: March 29, 2013, 02:21:35 AM »
Spud and I had some files that most of you don't have.  So we turned them off.   ;)
Re: Some SAK time
« Reply #9 on: March 30, 2013, 03:14:45 PM »
Great shots Neptune.  Thanks.   8)
« Last Edit: May 19, 2015, 08:19:27 PM by jeff3163 »
Re: Some SAK time
« Reply #10 on: March 30, 2013, 06:27:37 PM »
Skagway to Carcross- (Following the railroad line.)   8)
(Images now included in slideshow link at top of thread, I hope)
« Last Edit: April 21, 2020, 09:02:30 PM by jeff3163 »
Re: Some SAK time
« Reply #11 on: March 30, 2013, 07:24:30 PM »
Hi Jeff,
Great set of shots....the pictures just don't do justice to the great ride from Skagway to Carcross following the White Pass rail line.....the gorges, bridges and so on are spectacular.
« Last Edit: March 31, 2013, 02:28:00 PM by stiletto2 »
Re: Some SAK time
« Reply #12 on: March 31, 2013, 10:34:07 AM »
 . . . and then I continued up to Whitehorse, to finally complete the trip.
(Images included in slideshow link at top of thread.)
« Last Edit: April 21, 2020, 09:04:03 PM by jeff3163 »
av8erjm
Re: Some SAK time
« Reply #13 on: March 31, 2013, 11:46:47 AM »
Good Gawd, what kind of thermals or long johns are you wearing to be flyig around in the trike in temps like these. I'm seeing river and lakes frozen over, at the very least you should have frostbite of the face. BRRRRRR
Re: Some SAK time
« Reply #14 on: March 31, 2013, 12:07:21 PM »
 ;D  <--- Expression frozen onto my face!!
« Last Edit: March 31, 2013, 12:09:55 PM by jeff3163 »
