De livery is finished, so I'd better see that delivery takes place. A different form of showing screen shots here by the way. Clickable thumbnails that open in a separate browser window. Here's a sequence from the delivery flight:
There's still something bugging me on the exhaust, plus some very minor niggles that I may or may not patch. Depends on the screams of agony from my fan club
Anyone want it? It is for the Aerosoft Beaver Amphibian 1 i.e. the first Aerosoft Beaver folder in your menu structure in FSX simobjects airplanes:
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\SimObjects\Airplanes\Aerosoft Beaver Amphibian
There's a brief generic readme in the zip and you can get it by
clicking hereBrad/Doug - help yourselves for the library.
A BIG PS TOO
Folks, before I go to bed and forget to tell you, look at the zip very closely. There is a separate "mini" folder tree containing the interiors and pilots textures.
The texture.cfg textfile in the texture folder calls a new set of interior textures by means of the "fallback". You will have to copy the files from the last folders in the tree to their respective folders in FSX.
If you are on a newer Windows it is easiest by
a. opening the zip file in windows explorer and then opening up subsequent sub-folders untill you drill down to the folder containing the dds files.
b. open up an new iteration of explorer and drill down through the tree to the SAME NAMED folder in the Aerosoft Beaver folder library. You will have to create two new end-folders in "interiors" - "pilot_skinner" and "mistyclean"
c. left click drag 'n drop the dds textures from the zip to the same FSX sub-folder .
Of course, if you don't want my interiors or my pilot figure, you will have to edit the texture.cfg or you will get black interiors.
Have fun.
