Author Topic: GET to DX10 if you WANT  (Read 4101 times)
« on: September 15, 2012, 07:43:49 AM »
salvation
I give you the procedure taken AVSIM  of John Paul tutorial MES, SCRIPT file General STEVE JP and module télchargeable and implemented by the author  http://stevesfsxanalysis.wordpress.com/
1 / download version V2.01 V2.01 GENERAL 10   http://library.avsim.net/search.php?SearchTerm=DX10+shader&CatID=root
2 / Save the file SHADER HSLqui is in the root FSX by copying and pasting ... sometimes you want to switch back to DX9
3 / to FSX DX10 mode seen; close the game FSX
Start on 4/cliquez COMPUTER tab, right-click, and then click Properties in the Control Panel window click Advanced System Settings.
5 / In the window that opens System Properties, click the environment variable
6 / You're on a window called Variable Environment
6 / In this window look at the bottom of the second window you have three tabs; New, Edit, Delete.
New 7/Cliquez tab
8/dans the window that appears in the Variable Name Enter this, FSXDIR
9 / window you open your Hard Disk or finds its way to Microsoft Flight Simulator X
there at the top of the window in the path bar, point to Microsoft Flight Simulator X right click
In the window click COPY ADDRESS
you go again on "the form enclosed VALUE VARIABLE and you paste the path to this place more than OK is by closing the windows.
10 / Dézziper the General V2.1 STEVE JP
11 / Double-click the setup.exe ........... no right ADMIN
12 / say OK
13 / say OK
14 / Go to / / user / / name of your pc / / AppData / Local / / / Microsoft / / FSX / / SHADER 10 and remove
15 / Start FSX and go to your track choice and ADMIRE the result ....
ADDENDUM July 21
ADDENDUM very important
A FSX.CFG with DX9.0c with OR [DISPALAY device .......... ATI 7xxx .0] for AMD ATI owner
these lines [DISPLAY.Device.NVIDIA GeForce GTX 560 Ti .0] .0 at the end indicates the DX9
and if there will be several screens with this line at the end to a second screen .1 .2 a third .... etc..
in FSX, cfg
absolutely must leave this line if you are under DX10
[DISPLAY.Device.NVIDIA GeForce GTX 560 Ti .0] on. O at the end of a line indicates DX9
Because there the game will result in jerks and blue flash
And there will be just this line or lines for multiple screens
[DISPLAY.Device.NVIDIA GeForce GTX 560 Ti .0.0] .0.0 look there at the end of this indicates that you are in DX10
or a second screen, it will end in
[DISPLAY.Device. NVIDIA GeForce GTX 560 Ti .0.1] and .0.1 for 2écrans, 3écrans .0.2
You will be aware of this change in DISPLAY OPTIONS >>> From FSX
NVIDIA GeForce GTX 560 Ti .0.0 screen
NVIDIA GeForce GTX 560 Ti .0.1 second screen
NVIDIA GeForce GTX 560 Ti .0.2 third screen ... etc.
One important thing you have to put water in OPTIONS -> DISPLAY - Decor -> Water effect -> 2X max or under with the slider ..
At the same time corrects the umbrella effect on FSX dating from 2007 on the above link if AVSIM
 REX ESSANTIAL is essential for our FSX bloom for my config correct textures on SUN *natural look* in the FSX otherwise try the other effects BLOOM by choosing sun appearance at your convenience wink
An aside
by against me under DX10 in the tooltips, still appear in the cockpits
Good hack
additive 1 AOUT 2012
For those using REX in OPTIONS Essantial do not forget to check the DX10 OPTIMISED
or ASE12
at this end instal
You have to FIX the AA AntiAliasing in configurator CCC for ATI or Nvidia Inspector, Panel TOOL
PATRICK
