Author Topic: When FSX OOM error or another instal addon faile : HOW to OFF this  (Read 2403 times)
Dear ALL and ALL
You certainly have known these stupid messages in FSX, especially the most common end of the flight and you are about to save when suddenly .... a window appears with enough memory write ......... etc or  after add à plane an Error occured....
I recommend, if you have not already done so ....
To go on the FOLDER Microsoft Flight Simulator X games on your hard drive
Right click you will
window opens,
click PROPERTIES,
there you go to the tab MODIFY,
you allow all the rights,
In compatibility / / as an administrator and also your PC / Pat. your pc / / PC Pat
TOTAL control
you apply
and close with OK
And finishes bored of this cursed memory knowing that it was 4,8,12, see 16 giga MEM
hoping that it will serve you to no longer be bothered
PATRICK
