Author Topic: Starting Points for Sea Plane Bases  (Read 509493 times)
GrayRider
Re: Starting Points for Sea Plane Bases
« Reply #45 on: September 03, 2012, 06:36:36 PM »
I'm in the Tongass Fjords control panel.The "Static boats at Sitka and Petersburg marina" are not active.The checkbox is unchecked.When I tic it.What happens to the .BGLs.Are they moved from the Cache area into the Tongass_Fjords_Higher_Priority\scenery folder?.
For the other one,the TF_FSX_SPBs_and_marinas_ShoemakerBay_boats.BGL.I'll copy it and move it to the scenery folder Rod mentioned.I hope this is correct??.
GrayRider
« Reply #46 on: September 03, 2012, 06:39:16 PM »
Gray Rider,
Don't move any thing...just check it....it probably moves all three files.
GrayRider
« Reply #47 on: September 03, 2012, 06:59:38 PM »
I did tic the Static boats at Sitka and Petersburg marina in the Tongass X Control Panel.
I started my sim.It did not do a data build,as I though it would,since I activated something in the TF control Panel.
I'll report back of the results in a few moments.I'm heading to TF07 to have a look.
GrayRider
GrayRider
« Reply #48 on: September 03, 2012, 07:12:58 PM »
I just went to TF07.
Still no show of static boats
Here is a screenshot of what I guess is the Tongass X Control Panel.The upper far left box was unchecked.I ticked the box and hit the apply settings and exit.
I have this panel short cutted to the desk top,for use etc.
The three TF_FSX_SPBs_and_marinas_Petersburg_boats.BGL
TF_FSX_SPBs_and_marinas_Sitka_boats.BGL  files are now showing in the  scenery folder as seen in the screenshot below,that Rod had mentioned.
Still no static boats are showing up at TF07.
GrayRider
« Last Edit: September 03, 2012, 08:46:23 PM by GrayRider »
« Reply #49 on: September 03, 2012, 09:50:59 PM »
Hi GrayRider,
Now that you have the box ticked and the extra boat files are all in the scenery folder you need to go into your scenery library delete the Tongass_Fjords_Higher_Priority scenery area.  Then add the Tongass_Fjords_Higher_Priority scenery area back in by browsing to the FSAddon folder.   FSX will put the area on the top of your list.  Just move it back down to just above the low priority area which you left in the scenery library and it should work.
GrayRider
« Reply #50 on: September 03, 2012, 10:09:37 PM »
I'm working on it now Rod,following your instructions.
I will report back on what is there at TF07.
GrayRider
GrayRider
« Reply #51 on: September 03, 2012, 10:58:22 PM »
Thanks a heap to to Rod,Holger,Jeff and all others involved assiting in my no boats at TF07.
All I can say is Yahoooo!! I have boats.
Great support to everyone here at RTMM.It means a lot to me,being a PC dummy.
GrayRider
« Last Edit: September 03, 2012, 11:04:49 PM by GrayRider »
« Reply #52 on: September 03, 2012, 11:03:10 PM »
Woo-Hoo!!!!!!  Great news!
« Reply #53 on: September 04, 2012, 12:00:00 AM »
Yay!   ;D
« Last Edit: September 04, 2012, 12:01:56 AM by jeff3163 »
« Reply #54 on: September 04, 2012, 01:27:51 PM »
The difficult we do Immediately, miracles take a little time!
GrayRider
« Reply #55 on: September 04, 2012, 05:33:37 PM »
Yep on both counts.
Oh boy.I have some other things I'll deen help with,coming down the pike.
GrayRider
« Reply #56 on: September 04, 2012, 08:06:36 PM »
Yep on both counts.
GrayRider
Like dyslexia, maybe?  Just an observation.   ;D
HighGround
  • Throckmorton Throttlebottom
« Reply #57 on: September 04, 2012, 09:11:25 PM »
Reminds me of that old refrain:
"Old MacDonald was dislexic.
Oh-Aye-Oh-Aye-EEE
[/b]"
-Jon
Russell Lake, Dartmouth, Nose Kosher, Kanuckistan
