We have some new missions coming, and one great one posted for you. Jeff Greene has created a mission for the Dispatch 1 (Misty's Place Dispatches). You can now find it on the Missions Page. Also Brad Allen has updated the Wing and a Prayer Mission, and that update is available.
NOTAM: You can get to the Missions by going to Misty's Place and using the menu to select Missions, this takes you down to the table that links to all of the missions we will be posting. Misty's Place is becoming to "first stop shop" for activities in RTMM. When you are looking for something to do, go there first.
Give Jeff's Dispatch #1 a try, it is a very pleasant flight, even some music included. The weather can get a little tricky ... so be ready for that. And on the new Wing and a Prayer ... I think Brad has rated this as beginner, I would rate it as terrifying! :-) The weather and the mountain passes forces you to lock onto the instrument panel as you can see nothing out the front window. It is a while knuckle flight,
... good luck with both of them and our thanks to Jeff and Brad for getting this area going again.
