Author Topic: RTMM Objects Test  (Read 41141 times)
Hitchhiker
Re: RTMM Objects Test
« Reply #15 on: October 11, 2014, 07:04:47 AM »
Hi Rod,
Many thanks for the tips. As I've done all the installations as recommended, I unchecked all my other non-relevant sceneries, and as you suggested, one of the other sceneries must have EZ and RWY12 content in them. The only one I was aware of was the EZ Library I was using for an Ice Pilots scenery pack I was using, but I had disabled that (as it is not P3Dv2 compatible). But it seems like another scenery or sceneries contain libraries. It's now a matter of hunting down the culprit.
Thanks again!
« Reply #16 on: October 11, 2014, 11:27:58 AM »
Hi Hitchhiker,
I sure you will find it, just have to be methodical.
Hitchhiker
« Reply #17 on: October 11, 2014, 08:29:08 PM »
Have done :-) I have a tried and tested method of hunting down scenery culprits. SceneryConfigEditor (which is a blessing) makes it even easier. Main culprit was a freeware Oshkosh Airventure scenery that came with its own EZ Library, but there were a couple of others.
Thanks again for the tip.
« Reply #18 on: October 11, 2014, 10:22:36 PM »
Hi Hitchhiker,
Glad to know you have the problem fixed.
