Author Topic: New Type of VA  (Read 20086 times)
Re: New Type of VA
« Reply #30 on: May 11, 2012, 06:30:27 PM »
Hi Brad,
Fed Ex office at PAKT looks good!
Yep. ;)
« Last Edit: May 11, 2012, 07:05:06 PM by jeff3163 »
Re: New Type of VA
« Reply #31 on: May 11, 2012, 08:47:31 PM »
 . . . and I found a C-208B Caravan paint too.  (but no FedEx beaver)
Re: New Type of VA
« Reply #32 on: May 11, 2012, 09:33:51 PM »
Hi Fireball,
I must have mis-typed the hub selection...can you put me in PAKT?
thanks.
Re: New Type of VA
« Reply #33 on: May 11, 2012, 10:06:37 PM »
Hi Fireball,
thanks.
Rod,
     I think the hub selection was in a drop-down list (that you must've overlooked).  That's why your name was in the topmost hub in the list, by default.
« Last Edit: May 12, 2012, 01:09:58 AM by jeff3163 »
Fireball
  • Chris Losh
    • Northern Air Charters
Re: New Type of VA
« Reply #34 on: May 11, 2012, 11:44:58 PM »
I think I am missing something!!!!
Like the building :o
The 18 wheeler  ???
The sign on side of the truck :'(
Fireball
  • Chris Losh
Re: New Type of VA
« Reply #35 on: May 12, 2012, 10:08:35 AM »
OK I got the building to show up but note the trucks. I think we are going to need a bigger hanger. :o
alpha117
Re: New Type of VA
« Reply #36 on: May 12, 2012, 10:56:40 AM »
Hi Guys
Where do I get the Fedex scenery from?
|Clive
Fireball
  • Chris Losh
Re: New Type of VA
« Reply #37 on: May 12, 2012, 11:27:44 AM »
We are still testing it. A soon as it is approved it will get uploaded. ;D
Fireball
  • Chris Losh
Re: New Type of VA
« Reply #38 on: May 12, 2012, 11:35:46 AM »
TEAMSPEAK Server is coming up.
Re: New Type of VA
« Reply #39 on: May 12, 2012, 12:58:31 PM »
Folks,
To have this scenery show up, you should already have the RWY 12 object libraries installed. Those can be found on Flightsim.com searching for RWY 12. There are three libraries to have installed and we've been using objects from those libraries here at RTMM for quite some time. So make sure you do that first, then in the readme for the FedEx scenery for PAKT and all the other depots', you will see that you need to install a small scenery file that is a library of FedEx box trucks for use with this scenery.
Then you'll have access to the animated hangars that I'm using from the RWY 12 library and the FedEx trucks parked at the locations. To use the animated hangars, you tune into a frequency on your NAV2 equipped aircraft and the doors to the hangar will open.
Here are some shot's from the soon to be released Klawock and Wrangell FedEx depot's.
Klawock FedEx depot
Re: New Type of VA
« Reply #40 on: May 14, 2012, 09:14:46 PM »
We've made linkage to vNAC at Misty's Place in the Dispatcher's Office. You can find links to Chris' page there. For those crazy people like me that like to fly down on the water, I'll be putting in "low and slow" (below the 1500 foot ceiling) VFR flights to keep you over the water and low terrain when those ceilings are low. Our route numbers will match the FDX route numbers on Chris' site.  So if it is a nasty day (about 70% of the time up there!), and you haven't been checked out for instrument flying ... you can still earn a virtual buck. Grab that old airplane, put your GPS on the windshield ledge ahead of you and load on of the VFR flight plans for that route.
(If anybody wants to help with these, let me know.  I just require the .pln file, and I'll make the maps and do all the posting.  Just keep the flight over water or over very low terrain ... keep it "safe" for flying under 1500 feet. Let me know when you are going to do one, so I won't be duplicating it).
Re: New Type of VA
« Reply #41 on: May 15, 2012, 09:11:47 PM »
We now have 5 "low and slow" FDX routes at Misty's Place (Dispatcher's Office).  If you get tired of going up to 7500 feet, and flying a straight line to your destination, then give these routes a try. They are all designed for 1500 foot max ... so you will fly down low and "between" the dangerous mountains and up the narrow fjords of our beautiful RTMM area.  These flights put you DOWN INTO the scenery rather than just observing from a great height. You'll be amazed at what is down there!  Holger has put in nav markers for boats, there are all kinds of boats showing up too.
Just finding your way across the Sitka Peninsula, rather than going around it, can be a lot of fun, see the map for FDX004 (Sitka to Ketchikan).  These flights are great when the ceiling is at the typical 1500 feet for this area of the world and you still have to go from "here to there".  Give the vNAC group a "call" ... place a bid for an FDX flight ... download the Low and Slow Route from Misty's Place and put it into your GPS (Flight Planner).  Then, even when the weather is bad, go enjoy a flight and get paid some virtual bucks for your efforts.  If you love the scenery in the Misty Moorings area, then this is the way to fly ... down into it where you can enjoy the beauty, and danger, of it.
knswee
Re: New Type of VA
« Reply #42 on: May 23, 2012, 04:04:51 PM »
Great Idea, im in
